vdotmatrix
    Tue Nov 12, 2013 11:03 pm
    Northern Virginia
I have never used my welder for stick and I want to get one pound samples of E7018 and E6011 to try out.
I saw on a chart that these are for DC+.
What happens if you run these on DC- ?
ALSO: plastic?? The amazon ad reads this way. Any ideas?
Hobart H119944-R01 1-Pound Plastic 7018 Stick Welding Electrode, 1/8-Inch
Jack Ryan
    Wed Mar 24, 2021 10:20 pm
    Adelaide, Australia
vdotmatrix wrote: ↑Mon Feb 10, 2025 8:28 am I have never used my welder for stick and I want to get one pound samples of E7018 and E6011 to try out.
You need to check the specs for the rods you buy.
  • 6011 usually runs on AC or either polarity
  • 7018 usually runs on DCEP but if used for a root pass, DCEN is suggested because penetration is less and there is less chance of blowing through.
I would guess they come in a plastic pack.
Jack
vdotmatrix
    Northern Virginia
Thank you
Jack Ryan
    Adelaide, Australia
Tables of generalised electrode properties are a good indicator but the manufacturer's data is more accurate for a specific product.
On this 7018 data sheet,
The polarity is given as AC, DC+ or DC-. However, the note says that DC- is recommended for root passes.
Jack
vdotmatrix
    Northern Virginia
Jack Ryan wrote: ↑Mon Feb 10, 2025 10:26 pm Tables of generalised electrode properties are a good indicator but the manufacturer's data is more accurate for a specific product.
Jack
Thanks. I interested 6011 and 7018. My question is if you use other than the recommended electrode polarity, what will happen?
Jack Ryan
    Adelaide, Australia
Jack Ryan wrote: ↑Mon Feb 10, 2025 12:37 pm 7018 usually runs on DCEP but if used for a root pass, DCEN is suggested because penetration is less and there is less chance of blowing through.
As I said, for 7018, using DC- instead of DC+ gives less penetration. That is why it can be used for root passes.
I don't use 6011 but as it is designed for AC or either DC polarity, it probably doesn't make much difference.
Jack
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
vdotmatrix wrote: ↑Mon Feb 10, 2025 11:18 pm
keep in mind it will vary depending on manufacture and also your machine.
eg some machine won't run 6011 at all.
some rods say they will run but don't. some say they don't but can.
generally speaking running a rod on DC- it reduces heat and penetration. but some rods will run badly. eg some 7018's.
6013 can run very well on dc- and thats very useful on thin material. 7016's are commonly used on DC- for root passes for pipe (jody had video of that).
6011's i'm not sure on but i doubt you would want to.
tweake wrote: ↑Tue Feb 11, 2025 2:57 am eg some machine won't run 6011 at all.
Tweake I think you meant to say some lower end inverter type machines won’t run 6010. 6011 and 6013 are often recommended alternatives to that rod for these boxes.
Vdot, grab a pound of rods, try them on each polarity and see for yourself what the differences are. There is no substitute for live, field testing on your box with your hand to determine what works best.
tweake
    New Zealand
cj737 wrote: ↑Tue Feb 11, 2025 3:55 pm
no.
what i wrote is correct. some machines won't even run 6011, especially lower end inverters. i have some.
i had to get a really good middle of the road brand to get an inverter that runs 6011's well. i have nothing that runs 6010 well.
not many people use 6010/11 down here. 6013 and 7016 are the main ones.
LindaL
    Thu Jan 30, 2025 6:16 pm
E7018 and E6011 work best on DC+. On DC-, the weld will be unstable with a lot of spatter. "Plastic" likely refers to the packaging, not the electrodes themselves.
