Rodbelan
    Wed Oct 13, 2021 8:17 am
I bought a box of Blueshield 7018 rods (Air Liquide house brand). Not much info on packaging. I tried to run the rod, and boy, it was as if my welding table was a big magnet: the puddle was travelling front and back and side to side... never seen anything like it! I checked on the rod and it is labelled «AC». I ran many brands of 7018 and they were all pretty good (even some Hobart 7018 AC without any problem). I went back to other rods and they were fine... I wonder why it behaved this way; any cue? It is as if they were magnetized... (?).
It sounds like you’re suffering from “arc blow”. You can search for solutions to that in Jody’s videos on his YT channel.
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
what machine are you using?
i thought you had a DC inverter.
Rodbelan
tweake wrote: ↑Thu Aug 15, 2024 12:32 am what machine are you using?
Yes I do... Jasic Razorweld Razorarc 200 di.
It looks like an intense arc blow going on and on... I changed position and even pieces to weld; still behaving erratically...
AC rods should run ok on DC inverter; or maybe not always...
Rodbelan
cj737 wrote: ↑Wed Aug 14, 2024 12:15 pm It sounds like you’re suffering from “arc blow”. You can search for solutions to that in Jody’s videos on his YT channel.
Yes, great suggestion; but what puzzles me the most is that it's an ongoing arc blow... usually, you start your weld and at some point you start to get arc blow. In this case, the arc blow begins as soon as you light the rod... I'll need to do more tries. But I want to get it out of the way; is it possible that some AC rods could behave like that on a DC inverter?
tweake
    New Zealand
i would start by turning down the arc force.
AC rods will have a lower voltage requirement so you may need to set up the welder a bit different and also change your arc length a bit.
Rodbelan
tweake wrote: ↑Fri Aug 16, 2024 12:06 am i would start by turning down the arc force.
I almost always run my 7018 at «0» arc force... I like the buttery smooth feel. So, in this case, that's not the cause... I am talking of an extreme reaction... for exemple, even with a pronounced drag angle, the puddle rushes in front of the rod! Never seen anything like it.
tweake
    New Zealand
Rodbelan wrote: ↑Fri Aug 16, 2024 8:57 am I almost always run my 7018 at «0» arc force... I like the buttery smooth feel. So, in this case, that's not the cause... I am talking of an extreme reaction... for exemple, even with a pronounced drag angle, the puddle rushes in front of the rod! Never seen anything like it.
what amps are you running?
and what size rod?
Rodbelan
tweake wrote: ↑Fri Aug 16, 2024 5:45 pm
and what size rod?
3/32... running many amperage settings, from 70 to 85, depending of position...
tweake
    New Zealand
try a super tight arc.
