I have been stick welding for quite a few years and am pretty decent at that, but wanted to try tig so I just recently purchased an AlphaTig 200x. I am having an issue of some type of contamination. I am just practicing on 1/4"mild steel, 1/16" er70-s2, 3/32" lanthanated tungsten, 110-120A and about 12-15cfh on the argon. I am having issues with getting brown staining around the welds. I also having issues with splatter from I assume contaminated tungsten or lack of argon. At times the tungsten will suddenly produce a green arc like I dipped it in the puddle. I know this is not the issue because sometime it will do it when I initially light up and haven't added any filler. When I have the issue with the staining it also seems hard to make the puddle travel, that could just be me since im new.
That is a good example of the staining and in that case the splatter or eroding tungsten made a small cavity in the metal.
Here is another picture.
Now be easy on me I have only burned about 4 filler rods so far so you can say im pretty new haha.
Any ideas on a problem or tips to avoid this? I dont really care about the staining but the electrode eroding and splatter is obviously a problem and not good. Thanks in advance.
