Hope this makes sense. thanks
metaldreams
- metaldreams
OK so I did some but welds with 1/8" aluminum. They looked so pretty
. Then I ground down the weld and I noticed that I could see a line where the joint matched up. I was surprised because it seems to me this means I had only the most superficial penetration (yet the joint feels solid). So I tested how much time on my inverter it would take to get complete penetration and it was a long time at a lot of heat. I swear I almost saw the puddle drop as a sign of complete penetration. After complete penetration the metal shape was pretty distorted from the heat. Long story short what do you guys/gals look at as a sign you have adequate penetration to advance the tungsten when looking for complete vs only partial penetration
More power allows you to penetrate quickly and get moving - 3 seconds or less approximately.
170 amps starts the puddle quickly, you'll see the puddle drop very slightly - don't miss it as this will be your only signal.
metaldreams
- metaldreams
thanks. I just went out and tried 170 amps and wow what a difference. I was using the miller calculator and was working at max amps 127. I was under the impression that inverters need less amps than the calculator suggested .
thanks
thanks
Inverter based welders consume less amperage from the outlet. That doesn't change the amperage output requirement at the tig torch/tungsten.metaldreams wrote:thanks. I just went out and tried 170 amps and wow what a difference. I was using the miller calculator and was working at max amps 127. I was under the impression that inverters need less amps than the calculator suggested .
thanks
metaldreams
- metaldreams
Power is your friendmetaldreams wrote:thanks. I just went out and tried 170 amps and wow what a difference. I was using the miller calculator and was working at max amps 127. I was under the impression that inverters need less amps than the calculator suggested .
thanks
Dave is right power is your friend....crank it up and get moving.
metaldreams
- metaldreams
thanks everyone. I got into tig for thin aluminum so I was always afraid of burn through. This is the thickest material I have worked with. I will kick up the power. By the way I have struggled with fillet welds on aluminum but cranked up the power and it went like a breeze. Thanks again
