I'm a newbie hobbyist welder learning to TIG. I've been getting my seat time by designing and building my worktable, cart, mobility bases, etc. in steel. I've also been practicing on my aluminum. In the future I hope to build some furniture pieces and take a stab at bicycle building.
I have a 2015 AHP 200 which is capable of DC, AC (up to 200Hz) and pulse form 0.5 to 5 PPS. For whatever reason (i like nice stuff), I'm always on the lookout for a Dynasty. I have come across a Dynasty 200SD (box only for under $2k) but know it's upgradeable to a DX for $500-ish in parts.
So I'm wondering if the added features of selectable waveforms and higher frequency pulsing (up to 400Hz?) all packaged in a Miller blue box is something I should consider at a price tag under $2.5K? How much under 2.5K depends on what I can get the SD for. I would still have to come up with a pedal, torch, and cables. The new 210DXs boxes are $3.3K-ish.
I realize it's a personal decision (finances, goals, etc.) but was wondering from a technical standpoint, will these features be a worthwhile upgrade? Or just keep melting rods with my AHP until I outgrow it?
opinions?
thanks
steve
Since you're still "a newbie hobbyist welder learning to TIG" I would think the APH 200 would be more then enough to continue to improve your skills with. Your skills will take you further then an upgraded power source, later as you improve and perhaps find it's time to move beyond a hobbyist then there'll always be the latest tech waiting for you.
If on the other hand $$ isn't an issue then I would recommend a new 210DX as you'd have the latest with a warranty.
- dynasty200sd
The Dynasty 200's from serial number LK450153L and following, the board needing replaced only costs $110.
If memory serves me right, these are machines built from 2010 onward. The price listed is from Miller4Less. As to what only needs replacing, this is from information I found online researching the same topic. So, I am unable to vouch from personal experience this information is valid. With that said, I do plan on giving it a try; since the part's cost is not really expensive for my machine's build year.
Part# 244027 MEMBRANE, SWITCH CONTROL DYNASTY 200 DX
Dynasty200SD,
I have already contacted the seller and know that the serial number is old enough that it requires the $500 board. I suspect if it was the $110 upgrade that blue box would be sitting in my garage already.
Thanks for the other opinions. I needed a sanity check. While I'm blessed that I'm not constantly worried about $, I don't have too much of it sitting around that I can throw it around without serious consideration. Deep down I had a feeling that given a decent machine, working on skills always trumps upgrading. Back to the batcave to work on my skills.
thanks!
steve
thanks!
steve
Figuring out what I want to be when I grow up.
Better to be a "Learn it all" than a "Know it all"
hardhatdiver
- hardhatdiver
so I've never heard of upgrading the 200sd. so what a new board and face plate and your off and running?
I had a 2008 200DX I purchased at an auction. It lasted me a year before it crapped out on me. It would turn on but hang in boot mode. Quoted $1500 in repairs. Moved it on and purchased a 210DX. The Dynasty spoils you for adjustments. And the 210 has almost paid for itself in only a few months. If you have the means I highly recommend getting one.
I would not spend that much on a machine that old. I know that dynasty machines keep their resale, but that's an awful lot when you consider you are 2/3-3/4 of the way to the cost of a 210DX. I suggest using your current machine until you feel held back by it and understand the reasons WHY you are being held back. Then you can make your decision, and have more cash saved up too.
A big thanks to all for the input and reality check.
Borrowing a phrase from a former bike racer, it's not about the tool. I'll keep working on my skills and fertilizing my money tree until it's time to harvest.
steve
PS: Hardhatdiver, apparently a new front panel is all that's needed to access the functionality that's already in the controller. A google search will find info (weldingweb.com I believe) regarding what's needed. Older models require a $500 front panel and newer models only require a $110 panel.
steve
hardhatdiver
- hardhatdiver
