- Braehill
Robert,
I've never welded on an engine out of a ship as there's not much ocean in my neighborhood. I have welded a bearing journal web in an engine out of a payloader and did a block repair on a old Cat generator. The Cat engine leaked a little oil from the top of the weld but otherwise held up and the payloader lasted until they retired it a few years after.
It was a very long time ago for both of those so I don't remember all the particulars. I used high Nickel rods made for cast and the bearing web we packed with insulation (from the kiln on site) to let it cool slowly. Vee'd out from both sides and stitch welded it to try and limit heat input.
I wouldn't trust a cast repair on a ship that I planned on going through the North Atlantic with in mid-winter though, just saying.
First, off are the parts going to be machined afterwards? Second, can you get to the the parts to clean them and grind them? Third, does the parts have any kind of stress on them? I personally like the lincoln nickle rods-soft weld 99ni, soft weld 55ni, and ferroweld. The 99ni rods are good for a single pass but pre heat and slowing the cool down is critical, and they are machinable but expensive. 55ni is a good rod a little bit cheaper than 99 and are also machinable most of the time. They are good for parts that are thicker and can be used when more than one pass is needed, and they are less likely to stress crack than 99. The ferroweld is a good cheaper rod they really shine when the parts cant be cleaned really good, they are also really easy to run but CANNOT be machined. Now, the way I usually weld cast and this all is just my opinion and preference i clean it as good as possible, v it out if possible, pre-heat, weld short beads if possible, and after each weld I take a ball pien hammer and ping all around the weld and surrounding area, and when all the welding is done I take and wrap it in wool blankets to help slow the cooling down. Sand also works great if there small pieces and you have some. I hope this helps.
Brad
Brad
