toejam2889
- toejam2889
Kinda new to aluminum. Been playing around for six months now. Think I finally got the t joint down could you please critique.
toejam2889
- toejam2889
Okay will do. Thanks. I also have another question about filling a crack or a hole. I know your suppose to drill some kind of ventilation. But for what I was doing there was no way to drill. When I was just about to seal the crack my bead started to look like grey snot I couldn't add filler without it getting worse. What caused that to happen. No ventilation? Too much gas? The gas escaping in front of my weld puddle?
toejam2889
- toejam2889
Bill Beauregard
- Bill Beauregard
Any enclosed container will blow air out the last hole. Figure a way to allow the expanding air to escape. You can get a similar effect any time two flat surfaces lay together as in an edge, or lap joint. Hang back a bit with the arc. Instead of focusing on the leading edge of the puddle, stay back 1/16". On corner joints, use a backer. I have 1.5" copper square stock in a couple lengths, one corner is radiused to give the shape of a nice fillet inside. This traps shielding gas behind the weld.
toejam2889
- toejam2889
- 20150214_154242.jpg (33.36 KiB) Viewed 1219 times
toejam2889
- toejam2889
