- HeavyPettingZoo
HeavyPettingZoo wrote:I have an Eastwood 175. I can't get it to weld 1/10 inch mild steel exhaust tubing even at the highest amperage. I have it hooked up to my dryer electrical outlet. 75/25 gas.
PICS?
I haven't got a clue as to what "I can't get it to weld" means.
Welcome to the forum btw.
~John
- HeavyPettingZoo
I know this is obvious, but have you verified correct polarity on your machine?
Miller Dynasty 280DX
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Victor Oxygen-acetylene torch
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Bill Beauregard
- Bill Beauregard
Artie F. Emm
- Artie F. Emm
^^ What Bill says. Solid wire MIG is *typically* DC EP (electrode positive) while Flux Core is *typically* DC EN (electrode negative). To the OP, the electrode positive or negative is the polarity. Check the specs for the wire you're using, then change the machine's polarity to match. How to do that varies by machine: sometimes you jack the leads into the appropriate port, other machines require you to change buss bars or other internals inside the machine.
Dave
aka "RTFM"
aka "RTFM"
- HeavyPettingZoo
It's not a color-matching thing.HeavyPettingZoo wrote:Using solid core .023
Black wire is connected to the black - terminal. Red wire is connected to the red + terminal.
I think I have it correct.
If the red wire is on your ground clamp and the black wire is on your wire feed, then you're probably DCEN, and have it right for solid wire with gas.
If the black wire is on your ground clamp, and the red wire to your wire feeder, then you're DCEP which is right for most flux-cored wires without sheilding gas.
Steve,Otto Nobedder wrote:It's not a color-matching thing.HeavyPettingZoo wrote:Using solid core .023
Your mixed up.
Solid wire and gas is DCEP.
Self shielded flux core is DCEN.
- HeavyPettingZoo
That would definitely limit your output substantially if the machine runs at all. Wouldn't be good for it.HeavyPettingZoo wrote:So I'm now using .030 solid wire. Black clamp wire on negative terminal. Red wire feed on positive terminal
If I were somehow only getting 110v instead of 220v that might be giving me the problems I'm having?
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
- HeavyPettingZoo
xwrench wrote:That would definitely limit your output substantially if the machine runs at all. Wouldn't be good for it.HeavyPettingZoo wrote:So I'm now using .030 solid wire. Black clamp wire on negative terminal. Red wire feed on positive terminal
I'm calling an electrician and having a 220 volt 50 amp outlet put in my garage. I was going to do it eventually anyway. No more running a line from my laundry room. Wife will be happier this way too.
Artie F. Emm
- Artie F. Emm
Here's a link to your manual:
http://www.eastwood.com/images/pdf/12012Q_MIG175.pdf
Page 6 discusses polarity, and how to switch it- figures c, d, and e.
Cool that you're getting 50 amp service! The 175 only *requires* 30 amp input, but a 50 amp circuit will allow you some growth later, if you like. More power, Scotty!
Dave
aka "RTFM"
aka "RTFM"
- HeavyPettingZoo
- HeavyPettingZoo
Well after a two weeks a new drive motor and now a new gas solenoid my NEW welder is...STILL not working. I'm still waiting on the electrician to get the right voltage/amperage outlet installed in my garage.
In the meantime I've wasted an entire tank of gas trying to figure out what the problem is. YAY!
Good times!
Good times!
- HeavyPettingZoo
HeavyPettingZoo wrote:Well I sold the Eastwood 175 and bought a Miller 211.
WOW
What a difference! SO MUCH BETTER!
I mean in that it worked right out of the box and the Eastwood did not...
Devildog2076
- Devildog2076
