    Fri Nov 14, 2014 5:13 pm
After cutting down a 5.9 manifold to fit my 4bt going in my jeep I needed clearance between the turbo and oil cooler so this is what I came up with
Jeep Cummins transplant specialist
Here is the manifold modification
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
Awesome again!! ;)
Installed new oil drain
This is what I had before I moved the turbo
pigpen60
    Sat Oct 18, 2014 7:00 pm
    foley missouri
great job. is there a write up on your manifold cut and weld?
pigpen60 wrote:great job. is there a write up on your manifold cut and weld?
Not yet, but I can do one
This is the jeep receiving the cummins
    Tue Aug 19, 2014 2:34 am
    Short Creek, Arizona
Cool. Nothing quite compares to a proper turbo-diesel eh?
Miller Dynasty 280DX
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Victor Oxygen-acetylene torch
Nope, gonna have compounds hx30 over the he341
How much boost you figuring on running?
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
I am thinking somewhere around 45 maybe 50 psi
Wow! So according to my guesstimation, you'll be somewhere north of 800 hp from that four banger. Sweet! :D
Twenty years ago I had a readers rig of the month featured on "the diesel page". It was a 6.5 Chevy with most every mod that was doable with current technology. The latest generation of fuel systems and all blows that truck out of the water but I have diesel in my blood and love em all. Awesome project!
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
xwrench wrote:Wow! So according to my guesstimation, you'll be somewhere north of 800 hp from that four banger. Sweet! :D
Thanks! More to come, I will be manufacturing my own long arm suspension parallel to the cummins transplant
Pistons are headed to polydyn in Houston for coating:)
Went with 17.3 compression marine pistons
Wow! you pull no punches. Glad to see you're doing it right. :D
Cheers.
-Eldon
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
xwrench wrote:Wow! you pull no punches. Glad to see you're doing it right. :D
Cheers.
-Eldon
Also , I just became an authorized dealer for longevity welding equipment and can offer really good discounts on all machines. Ships directly to you from longevity
MSLiechty
    Tue Jan 06, 2015 11:22 am
Isn't the cummins 4 BT really loud? I have a 5.9 6BT. Love it but looking for an early model. Ist gen for a daily driver
    Tue Sep 17, 2013 1:12 am
    Valley Springs, CA
That things gonna be a tank! Put it in 1st and just tap the throttle and up the hill she goes. Nice mod, just be careful not to do what I did in my Suzuki Samurai.
Rolling over backwards is rather unnerving even if you end up back on your wheels, especially when your "roll-bar" is stamped unibody and the scissor-lift frame for your rag top. We drove it home 30 miles with no windshield and having to crouch down to Hobbit size, LOL!!!
Hood Time is a Good Time!
Avatar photo is from 1992, on Maui.
Stirmind wrote:That things gonna be a tank! Put it in 1st and just tap the throttle and up the hill she goes. Nice mod, just be careful not to do what I did in my Suzuki Samurai.
hacadacalopolis
    Fri Jan 31, 2014 5:14 am
    pensacola, Fl
Very cool Dzljon, Are you gonna run it on factory comp Or use tuning options?... Software, standalone...etc
hacadacalopolis wrote:Very cool Dzljon, Are you gonna run it on factory comp Or use tuning options?... Software, standalone...etc
No comp, it a full mechanical motor, I will put the 4k governor spring in with some decent injectors and I am going to try to cram a hx30 over a he341 in there for air
    Valley Springs, CA
No comp, it a full mechanical motor, I will put the 4k governor spring in with some decent injectors and I am going to try to cram a hx30 over a he341 in there for air[/quote]
That's what I like to hear, old school reliability meets new tech performance enhancements. You won't be able to kill it without a Barrett M99 .50 Cal, and then only if you hit the fuel rail or supply lines :lol:
Can't wait to see more pictures when you get a chance and want to share. Thanks again...Aloha, Chuck
hacadacalopolis
    pensacola, Fl
I see
Ill be tuning in for your Project.
