What's your favorite self shielded flux core wire to run for general equipment repairs. I've been running Lincoln nr212 and have been pretty happy with it for most of my repair work.
Miller Trailblazer 302 EFI
Suitcase Extreme 8VS
ThermalArc Cutmaster 52
Everlast Power I-TIG 255EXT
Good question.
I've found Lincoln to be the best, although, believe it or not, Forney makes some excellent flux cored wire.
The main thing is, treat it like 7018, meaning it absorbs moisture and will cause porosity.
Here's a redneck topic
http://forum.weldingtipsandtricks.com/v ... f=6&t=4338
2 cents,
John
2 cents,
John
I'll have to admit that I use my wire after a year or two but I only use it for non critical repairs and i keep it in a old fridge with a 100w light bulb in it to keep the temps up over 120f. I know its not a rod oven but my little 10lb ovens won't fit my 8in spools. It seems to work good for keeping out the moisture.
I bought a Hobart Handler 140 and it came with Hobart flux core wire. I ran it for a while but it was so expensive and didn't run very good at all. I bought Forney at the local hardware store, it was half the price and twice the wire. I don't always run flux core but when I do it's always Forney.AKweldshop wrote:Good question.
John
Matt
Matt
Matt
Sounds like I'm gonna have to try some forney. What is the number for the forney wires your running?
E71TGS and I am running .030 wire. I got a 10 pound roll for about $45. That is my local hardware price. I like the stuff it has done me good.
Matt
Matt
Lincoln, but I haven't run any flux core in a few years. When mig won't cut it, it's stick all the way.
I need to weld up a grapple for a friends track loader and I was going to give lincoln nr233 a try this time. Its all 3/4-1 1/4in ar400 and t1. It should be a fun project.
DSL power,
You realize that the T1 is quenched and tempered and requires a different procedure to weld than mild steel or AR400? I cannot recommend using Lincoln NR-233 when welding T1, as it only has a tensile strength of 70-95ksi and a Charpy V-Nnotch of 27ft-lbs. Mig welding T1 requires 110ksi and Charpy V-Notch of 50ft-lbs. If you already know all this, ignore it.
http://pc.arcelormittal.com/NA/plateinf ... 20WELD.pdf
Sorry I forgot to specify the T1 is the backing plate. I was planning on using 9018 rod for that. do you think that will be fine? I've used it before for a log loader repair.
Not knowing your exact design or strength requirements, first response is it should be fine. Although the T1 technically requires the 110ksi, this will vary with the job or WPS. For example, I did 3/4" T1 welded to A500 Grade B with Lincoln SuperArc LA-90 using 95/5. This gives approx. 106ksi using I think it was 250-300 amps, so we did not put to much KJ. This is what was required for the WPS, conformances, and design/use.
This grapply is just for a friends loader. We had another friend draw it up in autocad and sent it off to the steel place to have them cut everything for us since all we can do is freehand cut. They gave us a good deal on the cutting so we couldn't say no anyway. The plans where pretty much created by us and our previouse knowledge of what he wanted in a grapple there is no nice sheet of specs to go off on this one. This one is a demo that he's going to go beat on and if it holds up we might do a short production run of them.
Arizona SA200
- Arizona SA200
I've run a lot of NR-212 5/64 on big structural and its pretty nice.
Greg From K/W
- Greg From K/W
We have had a lot of problems with the Lincoln flux core shorting out in the shield lining. It shorts out and will stick. Won't let it continue feeding through.
Has anyone noticed that with the Forney? Maybe its my buddies machine. He has a small lincoln 180 mig/ flux core machine running on 40 amp dryer line.
I've never experienced that on my machine and all I've run through it is Lincoln. I am going to have to try Forney once I get all moved into my new place.
You guys will be amazed how good of quality Forney Fcaw wire is....
I've ran 50lbs min of it in a Lincoln weld pak hd( 88amp machine)
It runs smooth and very porosity resistant....
Try some... DCEN....
Weld on!!!
~John
Weld on!!!
~John
I have a Hobart Handler 140 and I ran straight Hobart flux core in it but it was so expensive so I got some Forney flux core at our local supplier and it is twice the wire than the Hobart wire is. It is a lot smoother and better running stuff. I have also ran lincoln and would not run it if it was the last spool I had. I also have some Forney stick rods and they seem to do pretty good. I always ran lincoln rods with no trouble and I feel the Forney do just as good as the lincoln and Hobart rods.
Matt
Matt
Greg From K/W
- Greg From K/W
I will be looking around for some Forney wire thanks for the compare guys. Much appreciated. I also got some 7018 forney rods at a local Habitat restore and picked them up I think for $10 for a 2 pound bag sealed. They ran great. SMoother than the licolne rods. If I can find a supplier around here I will be getting more.
