Hi guys I weld a lot of aluminum and I have gotten accustom to the wet flowing puddle.
I have some repetitive 304ss jobs in the shop and I can’t get the hang of the stiff dead puddle.
When I try to dab and drag method my filler wants to stick in the puddle.
I done some research and found a 304 LSI filler rod claming to produce
wetter more fluid puddle.
Any one used this filler?
Chris
I am curious. Where did you find a 304 filler metal? The SI in LSI means that silicon has been added to improve wetting. It helps compared to standard stainless filler metal but it is still a little stiffer than mild steel.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
I was gonna say, you would have been the first with a 304 filler. Yes, I have used it (308) and I don't mind it. It wets pretty good.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
I like it. Any time I can use a filler that wets better than another without compromising weld strength (when needed) I use it. Makes my job a whole lot easier.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
