Left a message, no call back so let me try here. Bought 2 stubby gas lens kits at separate dates quite apart. One was for a friend with a Lincoln 17 torch and mine for a CK 26.
Both kits don’t grip the tungstens right. I can still slide the tungsten despite a lot of hand force to tighten the back caps. I as if the collets are slightly too short. Both kits were used only a few times so not worn out. Used a lot of torch’s over the last 36 years of TIG welding and never had this issue. What is the problem here?
- metalman21
Hi mate. If you are chasing weldmonger than you may not get much results here, they dont have much to do with this.
I find the easiest way to get a hold of them is thier email address.
info@weldmonger.com
I have had delivery issues before and they usually very good, much better than most stores.
Hope it helps bro
info@weldmonger.com
Hope it helps bro
BillE.Dee
- BillE.Dee
sounds like the wrong collets for the gas lens. could be a mix up on either end. When you set the collet into the gas lens does the collet stick out a bit? and are the collets the proper size? Stuff does happen.
- metalman21
The kit comes with 2 insulators and only one fits the CK26, the other is a smaller diameter. I'll have to take another look at the one we put on the Lincoln 17, that one slips more.check that your using the correct insulator.
its been a while but i think there is two in the kits and you need to swap the stock one for the correct one.
Proper size? These are the collets that came with the kits. I think the collets are slightly short. I don't know what you mean by sticking out a bit. It bottoms out in the collet body where there should be a small taper and the plug end is below the threads for the plug/cap.sounds like the wrong collets for the gas lens. could be a mix up on either end. When you set the collet into the gas lens does the collet stick out a bit? and are the collets the proper size? Stuff does happen.
The collet body is firmly tight into the torch with a small wrench. If the collet body is loose or not in all the way it would also cause the problem.
Ernie F.
