RonEasley
    Mon Feb 01, 2021 5:40 pm
    San Antonio, TX
I need to fix a cooking pot (handle broke off)
The pot is stainless but I have two thickness of metal
The handle is 0.075"
The pan is ~ 0.025" - 0.030"
As you can see the spot welds failed.
My dilemma is: I don't want to blast a hole thru the thinner walled pot
Should I drill my holes thru the thinner pot to weld to the handle and then blend the welds in?
OR
Should I drill thru the handle to connect to the pot?
TIA,
Ron
Ron E
EZ Metal Werx
San Antonio, TX
Mattman06
    Wed Jan 13, 2021 12:42 am
    Fort Walton Beach Florida
I'm a noob, but I would drill the handle and tack it to the pot. I'd put some tacks around the outside of the handle too. I'd start the puddle on the handle and try to walk it over to the pot. Not sure if this is good advice or not. Somebody with a lot more experience will respond soon.
Lincoln mig 210
Lincoln tig 200 everlast cooler
Miller plasma cutter
An even easier/stronger repair is the drill the handle. Then mark and drill the pot. Stainless screws thru handle into pot. Weld the screw ends to the interior of the pot, after grinding them flush. Blend and polish to finish.
    Wed Jan 22, 2014 12:00 am
    Connecticut
I would drill a few holes in the handle and then plug weld to the side of the pot. You may want to back purge to prevent sugaring. You can overfill the plug welds and blend them if you want.
Multimatic 255
robtg
    Sat Aug 04, 2012 3:54 pm
    San Jose Ca.
Rivets. A couple of hand made stainless rivets.
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
why not braze it on?
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
Spot weld the holes and then weld around the outside a little. Quick and easy.
