I don't have any more projects I 'need' to build at home as I learn to weld. So... I'm going to play around with some fun artsy things. I found a cool optical illusion square I'd like to try. It's mostly just a bunch of miter welds that will allow me to practice with thinner square tubing material as well as consistency of fabrication. I'd love to learn how to polish, and seal, a project like this. My projects so far have been either painted or left bare to rust decoratively.
My question: I want this to be a high shine polished look. Does that mean I'll need to buy a series of flapper discs of varying grits? Are there any simple ways to achieve that look especially in tight spaces where a grinder might struggle to reach?
And... how would you seal it once finished?
Thanks in advance.
Hobbyist MIG welder with 75/25 gas on a Lincoln SP-140 in my garage/workshop/gym/storage space. Very new and still learning.
"Service is the rent you pay for room on this earth" - Shirley Chisholm
Sprockmonster
- Sprockmonster
Ive had luck cleaning/polishing machined surfaced on heads using a 90 degree die grinder and those twist lock scotch bright pads. Can get all you need at the freight for around $30. Including the die grinder.
If you are trying to polish carbon steel to a high shine, you’ll be a while, use numerous grit disks or belts, and still have miles to go. Switch to stainless. It will polish up to a mirror with the right amount of work.
Using a flap disc on an angle grinder will impart some fairly deep scratches. You’ll work to get those out before you get very far “polishing”. A Dynafile works very well in tight spaces.
Mike Westbrook
- Mike Westbrook
90 degree die grinder with a scotch bright roloc wheel is about as good as it gets wipe with acetone or reducer warm it then clear it asap
Sent from my XT1254 using Tapatalk
This all makes sense except the last part. I am not familiar with the "warm it then clear ASAP" part. I can see myself setting the whole thing on fire with a torch. Can you be a little more specific for the noob so I don't ruin the project or burn down my house?Mike Westbrook wrote:90 degree die grinder with a scotch bright roloc wheel is about as good as it gets wipe with acetone or reducer warm it then clear it asap
Just a slight warm, so it's not freezing (maybe only putting it under a hot light) and then putting a coat of clear lacquer or varnish on immediately to prevent rust.
Mike Westbrook
- Mike Westbrook
Yeah what Mike said [emoji6] it makes the clear set faster to help with runs
Thats solid help. Thanks for the feedback. I'm in Phoenix so the frigid 60 degrees might not need much warming. But I'll give it a little warming love to speed the process.
Thanks again. This forum and all of the experts are always great.
I did some research and I'm not sure I have the set up to weld Stainless Steel as I only have a mig machine (Lincoln 140) and I only have a 75/25 tank option. Not sure the hobby nature of this project warrants me spending money on new tank and filler wire.cj737 wrote:If you are trying to polish carbon steel to a high shine, you’ll be a while, use numerous grit disks or belts, and still have miles to go. Switch to stainless. It will polish up to a mirror with the right amount of work.
Josh MacD wrote:I did some research and I'm not sure I have the set up to weld Stainless Steel as I only have a mig machine (Lincoln 140) and I only have a 75/25 tank option. Not sure the hobby nature of this project warrants me spending money on new tank and filler wire.cj737 wrote:If you are trying to polish carbon steel to a high shine, you’ll be a while, use numerous grit disks or belts, and still have miles to go. Switch to stainless. It will polish up to a mirror with the right amount of work.
By the way, the correct formula for determining how many welding machines you need is N+1. Please bear that in mind as you go forward
