You can't use that machine for welding aluminium (very easily) as it is a DC mig/stick /tig. For learners and basic stuff you need an Ac/dc tig welder.
Yep mate, steel, stainless steel and any other material that states DC electrode positive for welding. Aluminium requires AC cutting, the constant change of polarity is used to break down the aluminium oxide layer.
If you tig the stainless, you'll probably have a better outcome with DC electrode negative, though...weldin mike 27 wrote:Yep mate, steel, stainless steel and any other material that states DC electrode positive for welding..
His statement was and steel can be TIG welded, plus the OP can weld anything set for DCEP. All DC TIG is set for DCEN, but the machine can also do DCEP.Lightning wrote:If you tig the stainless, you'll probably have a better outcome with DC electrode negative, though...weldin mike 27 wrote:Yep mate, steel, stainless steel and any other material that states DC electrode positive for welding..
