what is the best type of tungsten for Aluminium welding
I'm using a Thermal Arc ArcMaster ACDC 300
at present i'm using white tip
thanks
Simon
If your machine is a transformer, then use pure (green) If it is an inverter, 2% Lanthanated is the best all around tungsten but others might disagree. I used some E3 awhile back on some AL and I thought it did a good job.sistack wrote:what is the best type of tungsten for Aluminium welding
thanks
Simon
- Farmwelding
Lanthanated or ceriated is what I use. THey both run pretty well. Like most things there is a bit of personally preference to a point. What you may want to do is pick up a variety of reccomendations electrodes and figure out what you like best. Oh and don't use pure in an inverter ever cause it balls up too easily.
kiwi2wheels
- kiwi2wheels
There's two types of zirconiated tungstens , brown (up to 0.4% Zr) and white (up to 0.8% Zr)
https://www.millerwelds.com/resources/a ... er-welding
If the white you have works, holds a stable ball, doesn't spit inclusions into your weld and you don't have a problem, stick with
it. Maybe experiment with other grades if you cant get the arc shape/point you want. Plus some inverter machines seem "kinder" to the tungsten on AC than others.
Brown used to be the standard when electrodes were US made and there were never any issues. It was the only thing to use if you were machining a welded component, because of no tungsten inclusions. In Europe these days, the quality of white is scheisse and you use what ever works. I had an instance with some 4mm white on a 500A inverter that were unusable on any settings and had to use pure, which could just be made to last, only because that was all we had .
As all tungstens are now made in China, its a bit of a crap shoot brand wise, unless you go with a brand like C&K.
Jody did a video on this and 2% lanthanated stood up the best. That's what I run on my Syncrowave. I use a 1/8 inch electrode for heavier situations like quarter inch plate, and I don't even ball it.
Multimatic 255
- maker of things
I like 2% lanthanted on both inverter and transformer machines too.
-Jon
Lincoln Viking 3350 K3034-2&3
Lincoln Power Mig 180c
hermit.shed on instagram
Hey Simon,
I would pickup some 3/32 Lanthanated or Ceriated both should work very nice with your machine.
Pete
Pete
Pete
All I use is E3 (purple) and those are really good, work on both AC and DC, steel, stainless, aluminum etc. Only gotta keep one type on the shelf.
Otherwise Zirconiated or Ceriated are also pretty good I hear, never tried them but I have heard good of them.
- GreinTime
Boooooooooooooooooo!!!!!! I hated E3 every time I ran it!Olivero wrote:All I use is E3 (purple) and those are really good, work on both AC and DC, steel, stainless, aluminum etc. Only gotta keep one type on the shelf.
Sam...can you elaborate? I tried some E3 and I thought it did a decent job. It was 1/16" on super thin AL so I didn't really get to put it to the test but I had no trouble with it balling nicely or splitting.GreinTime wrote:Boooooooooooooooooo!!!!!! I hated E3 every time I ran it!Olivero wrote:All I use is E3 (purple) and those are really good, work on both AC and DC, steel, stainless, aluminum etc. Only gotta keep one type on the shelf.
You're gonna get cancer bud! That stuff is radioactivePoland308 wrote:I'm in the dark ages I use thoriated, in 3/32 and 1/8.
You too huh?Poland308 wrote:I put the new one in my mouth while I take out the old one.
- Farmwelding
Yeah and the water I drink on the farm is gonna cause me to have nerve issues. Used to have a little arsenic. Cows never showed it after thousands of gallons each and no one in my family got sick or had issues. Then they filtered it out and now it tastes like crap city water. And besides when you're welding galvanized steel or wire brushing a 1/16" layer of rust that is really when you have to worryexnailpounder wrote:You're gonna get cancer bud! That stuff is radioactivePoland308 wrote:I'm in the dark ages I use thoriated, in 3/32 and 1/8.
Worry about what? I make sure when I weld galvanized that I have my hood over the weld so I get a nice dose of fumes...heard it keeps you from getting colds. Rust? Other than getting some pretty shop boogers, what is wrong with rust?Farmwelding wrote:Yeah and the water I drink on the farm is gonna cause me to have nerve issues. Used to have a little arsenic. Cows never showed it after thousands of gallons each and no one in my family got sick or had issues. Then they filtered it out and now it tastes like crap city water. And besides when you're welding galvanized steel or wire brushing a 1/16" layer of rust that is really when you have to worryexnailpounder wrote:You're gonna get cancer bud! That stuff is radioactivePoland308 wrote:I'm in the dark ages I use thoriated, in 3/32 and 1/8.
- GreinTime
My experience with it has been at the upper limits of 1/8" tungsten on a Syncrowave 250 and Lanthanated out performed it. We also tried it with our robotic TIG welder, and Lanthanated outperformed it within the range of a 3/32 tungsten every test we ran.exnailpounder wrote:Sam...can you elaborate? I tried some E3 and I thought it did a decent job. It was 1/16" on super thin AL so I didn't really get to put it to the test but I had no trouble with it balling nicely or splitting.GreinTime wrote:Boooooooooooooooooo!!!!!! I hated E3 every time I ran it!Olivero wrote:All I use is E3 (purple) and those are really good, work on both AC and DC, steel, stainless, aluminum etc. Only gotta keep one type on the shelf.
I also think 2% Lanthanated is "the shit" but I was in a pinch and all that the LWS had in 1/16" was E3 and it served the purpose. Would I switch to it? Never. I was at the welders candy store yesterday and almost popped for a pack of Quad and Rare Earth but thought better of it and got more 2% Lan. Your opinion on Quad and RE?
Well, I never tried letting a robot do my welding for me and I only use 3/32" as I rarely need to go above 200 amps on the stuff I build but I've built a lot of stuff with E3 and it works great for me.
Don't know what to say to that, could get into one of those "my dad is stronger than yours" arguments, but why bother. I should really try Lanthanated though..........
LWS told me of E3 and had me at hello on that one. Used to use the hazardous OHMAHGOD HES GRINDING IT! CLEAR THE ROOM! 2% Thoriated but figured I would try something else and now all I use and have been using for a year is E3. Tried the 4% thoriated rod (HOLY SHAAIT) didn't feel any difference whatsoever, started growing gills after that though, darn radiation.
- GreinTime
Like I said, I'm sure within the recommended range, it's fine, but 2%La has held up better when exceeding it. Zircononiated tungsten held up better on the Syncrowave at 310 than any of them actually, but that was a fellow welders personal stash. The company supplies La/Th/Pure for us to use.Olivero wrote:Well, I never tried letting a robot do my welding for me and I only use 3/32" as I rarely need to go above 200 amps on the stuff I build but I've built a lot of stuff with E3 and it works great for me.
The robot makes 41 arc starts in 2.75 minutes, some pulse some straight amperage, so in an hour, it might get the same number of arc starts some get in a week. Start repeatability and accuracy is paramount with the robot, and we've found that the La outperformed the E3 with specific regards to this project. I'm trying to get them to switch to 1/8 and it will eliminate the problem totally, but we'll see how that goes. They are using 1/8 on the cloos across the shop and aren't having any tungsten degradation issues at all with the amperage we are using.
kiwi2wheels
- kiwi2wheels
- GreinTime
CK Brown Band as far as I know, I'll double check with you. 1.5% if memory serves correct?kiwi2wheels wrote:Could you find out what brand and color these were please ?GreinTime wrote:
kiwi2wheels
- kiwi2wheels
Thanks. I contacted CK 18 months back about the brown; they said it brown tungsten was 0.3% zirconium and the white tungsten is 0.8% zirconium. I found an old (July 2000) catalog that listed brown as nominal 0.25% and also has a recommendation for using 2% thoriated for al/mag with 75% argon/25% helium with AC. No mention of whether transformer or inverter. However, this does.GreinTime wrote:CK Brown Band as far as I know, I'll double check with you. 1.5% if memory serves correct?kiwi2wheels wrote:Could you find out what brand and color these were please ?GreinTime wrote:
http://www.thefabricator.com/article/al ... minum-gtaw
Another
