ryanjames170
- ryanjames170
i would get a test scrap and start playing with settings and stick out to figure out the issue.. start out with what you have for settings now and then crank the settings higher or lower on voltage and wire speed.. also if what you are welding is cold ie the themp is cold enough to warrent a jacket for you try a little preheat.. summer settings wont always work in the winter no matter where you live..
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
RM Fab & Products
