Silly question I guess. Does a water cooled handpiece have an effect on the weld? Or for user comfort, and perhaps preserving the tungsten a bit?
I've never seen this addressed, only referred to. (Don't end sentences with a participle, I only did it here for dramatic effect)
Thanks!
dirtmidget33
- dirtmidget33
Cools torch down which allows smaller torches to handle a higher amperage then an air cooled torch of same size. For example a CK 20 water cooled and CK 9 air cooled are the same size but CK 20 is rated for 250 amps and CK 9 is rated for 125. Also water cooling keeps torch cooler to the touch, a CK 9 at 125 amps gets hot really hot quick. While the CK 20 stays at a comfortable temperature to hold onto it depending on cooler too. Makes it a lot easier for long constant runs on hands. If you don't turn on the cooler on a water cooled torch you will burn it up also quick.
Water cooling has no effect on the end result. It only keeps the torch and your hand cooler. There's also very little trade-off in weight. In fact, it's my impression that a water-cooled torch is lighter in the hand, as the circulating water in small lines weighs less than all the copper needed for an air-cooled torch of the same capacity. (The power lead in a water-cooled torch is INSIDE the return line, so is water-cooled itself. Where you might need 1-gauge cable for an air-cooled torch, the power comes through a 10-gauge wire inside a water-jacket.)nelson wrote:Silly question I guess. Does a water cooled handpiece have an effect on the weld? Or for user comfort, and perhaps preserving the tungsten a bit?
Thanks!
Thanks! That's good to know.
Yeah about that not welding with a water cooled torch when the cooler is not turned on...
Did you know the non-conductive coolant use in the machine smokes up like a mother when you weld with the cooler off...
Took 20 minutes for the smoke to clear in my garage...and I go the pleasure of buying a new torch.
How long did you weld without coolant?
my first TIG machine was an old Goldstar (circa 1950)
and i had to turn the chiller on with a separate switch.
never burned up a torch but fired a few hoses.
I'm new at this. Forget to plug the gas in once. Took me 4 strikes and a few minutes to catch on.
I guess it's good I don't have water to goof up. I have plenty that I can screw up.
EricVonSplatterlot
- EricVonSplatterlot
So speaking of water cooled...I'm currently running a Lincoln Power Mig MP 210 with a stubby 17 style and thinking of upgrading to a water cooled. Any suggestions? Maybe one that would accept the 17 accessories or would I have to purchase all new?
Thanks,
Eric
Thanks,
Eric
