DIY Tripod Hoist advice suggestion
Posted: Fri Mar 28, 2025 10:31 am
https://youtu.be/NfeAPqCrT1Q
Hi, surfing the net I saw the video of this gentleman who made this tripod to lift weights. I thought that a similar structure to lift small loads could be useful to me but in iron not wood. How do you recommend I make it starting from that project? I would like to make the iron legs 3 meters high, capacity 300 kg, do you recommend three legs or four to make the structure stable, underneath I should put the box of a small truck to load it or use the structure in the countryside when I need it thanks best regards
https://youtu.be/gusJRlYucAY
https://youtu.be/b-lMACuKWqA?t=1
https://youtu.be/-ZgidbeGqtA
https://youtu.be/vBrToczfi4g
