Four uprights. Two on the left go further down, over the bandsaw. Arms are 1.5 sq 0.120 wall 18” long. Verticals are 1/4 x 3 flat bar. Will be anchored to wall with 3/8 anchors. I don’t plan to put a large amount of stock on it.
I settled on a 3 degree up angle for the shelf arms. The Ellis saw made easy work of the miters. I made a layout template on the laser to make sure I put my mounting holes in the right place. Made in two pieces due to the width of mdf sheet and laser bed.
1/8 mdf is much easier to hold up to the wall. Also made small test pieces for the shelf arm end caps to sort out the size.
Now I have a lot of helmet time. I need the practice. Switched hands with the torch and filler. It’s going better having the filler in my dominant hand.
