Still need casters.
Getting better with my welding. Practice does indeed make a difference!
I had a piece of 3/8” plate waterjet cut.JayWal wrote:Nice sturdy frame. What are you using for a top?
I hear you!Oscar wrote:Dang, there's some busy bee's on this forum as of late. I almost can't keep up with new threads/posts! It's like a gust of fresh air when you open the shop doors! Lots of projects recently from professional repair, to serious DIY hobby type stuff, and everything in between. I wonder why this place is soooo much better now..?!?!
Time to get out into the garage and at least clean-up and get ready for the weekend!
I’ve had really good luck restoring cast iron tops on saws etc using a purple 3M belt on my belt sander.cj737 wrote:How are you planning to treat the surface? That looks like a lot of scrubbing to remove that surface rust.
How do you clean it? I used a sheet of 3/4 plate, I still have the mill scale on it. Doesn't bother me at all yet in fact I'm guessing spatter might stick a little less on scale than on bright shiny plate. It would look better polished up im surecj737 wrote:Oh there's ample options for sanding, mechanical removal that all work well. I was just curious if you were going to chemically remove it instead. Shouldn't take hours no matter which route you go. Even periodic treatment of my 72x48 table only takes a solid 30 minutes every couple of months to get it back to shiny and bright.
Using that 3x21 - ish belt sander? Is it like a felt/fine-grit abrasive belt?DavidR8 wrote:I’ve had really good luck restoring cast iron tops on saws etc using a purple 3M belt on my belt sander.cj737 wrote:How are you planning to treat the surface? That looks like a lot of scrubbing to remove that surface rust.
This is my bandsaw table.
Before:
After.
Yes, it’s a 3x21 sander.Oscar wrote:Using that 3x21 - ish belt sander? Is it like a felt/fine-grit abrasive belt?DavidR8 wrote:I’ve had really good luck restoring cast iron tops on saws etc using a purple 3M belt on my belt sander.cj737 wrote:How are you planning to treat the surface? That looks like a lot of scrubbing to remove that surface rust.
Before:
After.
CRC SP350 does a pretty good job at keeping the surface from flash rusting or pitting. I clean the surface regularly (well, maybe not as often as I think I doDavidR8 wrote:@cj737 I gave the top a quick go with the belt sander so I could build the legs. Once I put the top on it I'll go at it a bit more seriously.
Do you put anything on the table top to keep it shiny?
I had my plate Blanchard ground both sides. So it was really nice and shiny.JayWal wrote:How do you clean it? I used a sheet of 3/4 plate, I still have the mill scale on it. Doesn't bother me at all yet in fact I'm guessing spatter might stick a little less on scale than on bright shiny plate. It would look better polished up im sure
This is a really good choice too. Mine is inundated with 5/8" (16mm) holes on a 2" (50mm) grid. Bluing those holes would be a nightmare! As it is, I do have to run a die grinder with a wire brush in them now and again to keep them clean and gunk free.Coldman wrote:I blued mine and wipe it down every few weeks with inox. Never gets rust and spatter doesn't stick although I mostly tig, occasional mig.
Mine's holed out same. Bluing the holes wasn't nearly as bad as drilling em. To clean em every so often I use spaypak brake clean and compressed air. Takes 5-10 mins. No biggie.cj737 wrote:This is a really good choice too. Mine is inundated with 5/8" (16mm) holes on a 2" (50mm) grid. Bluing those holes would be a nightmare! As it is, I do have to run a die grinder with a wire brush in them now and again to keep them clean and gunk free.Coldman wrote:I blued mine and wipe it down every few weeks with inox. Never gets rust and spatter doesn't stick although I mostly tig, occasional mig.
If you do, purchase annular cutting bits. Skip the twist drills. Your holes will be “machined” quality, cut faster, and blow through in seconds. Literally.DavidR8 wrote:I’m thinking about renting a mag drill so I can put in some clamping holes.
Considering picking up another set of import Teco-style clamps that are used for milling machine setups as hold downs and stops.
