Middle Buster
Posted: Wed Dec 05, 2018 2:48 pm
Just for something new to look at, here’s another farm project I kept some pictures of. I had some time last summer to make a 3-point middle buster for digging potatoes. Digging potatoes by hand is about as fun as amateur eyeball surgery, so I was desperate for an escape plan. Also, I’d seen how cheaply made the ones they sell locally are, and… well you know the rest of the story
If you see something I could be doing better/smarter, please let me know. I’m always making things like this and would appreciate any pointers.
We live on a centennial farm so there's steel everywhere you look. It's all older than me so forgive the fine patina.
I have a Swag press brake for my small press, but I have to heat thicker stock to be able to bend it. Same goes for anything cold roll. They crack if I don’t heat before a major bend.
Drilling holes for the lift arm pins:
Temporarily bolted the arms where I wanted them. I think this flat bar is in the neighborhood of 3/8" x 2-1/2".
Laying out the cross bar (~1/4" angle with 2-1/2" legs, I believe):
Welded up with 6011, then 7014 (only had AC):
Had to buy some 1" x 4" for this and another implement I was making. I don't have a terrific sense of how thick I need to go for these kinds of things, but I'm probably overdoing it.
Not sure how many passes would be "enough" to hold the shank to the frame.
So I went with a belt and suspenders approach
I've used this for two seasons now and I still need to buzz off these sharp corners
Doing a test fit-up to make sure I have enough ground clearance. I wanted to get maximum digging depth, but still be able to drive around without scraping the ground with it fully raised.
I didn't get great photos of the foot, but the idea was to be able to get two bolts through it in order to mount the plow.
Again, I just ran 6011 and 7014 over all these. Until a couple weeks ago I only had the AC machine and had never run 7018 before.
Here's the plow mounted to the foot. It's around 16" across at the widest point of the wings and I picked it up new for $18 - much cheaper than I thought it would be.
Just a closeup to see how it's mounted.
Wasn't sure how much horsepower it would take to run this, so I put it on a 45HP tractor. (turns out it digs potatoes just fine on a 30 horse machine, at a depth of about 10")
I did quite a bit of stress testing with it to see if it would break, and I think it's sturdy enough for light abuse. I ran it at full depth (~22") at about 5mph and nothing snapped. I also dug a little ditch to help drain a field at the bottom of a hill just to see how that would go. I caught my kids lounging in it after the first big rain we had
Made a little point for ripping through the subsoil to help with drainage here and there.
Overall this was really fun build. Like I said, we've used it to dig all our potatoes (about a 1/4 acre) for two seasons and it's been a life saver. If you see anything in the pics that looks off/dangerous/stupid please let me know. Now that I have a DC machine I'm learning to run 7018. I'm pretty lousy at vertical and overhead so that's what I'm practicing these days.
-Brandon
-Brandon
