motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
here we go again another table build
corners welded than ground smooth.
maybe ill get a new welder out of it (doubt it though)
motox
    Delaware
corners
IMG_1595 corner 2.jpg (125.21 KiB) Viewed 3068 times
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Fine work, matching the heat tint.
    Thu Dec 25, 2014 9:25 am
    near Chicago
motox wrote:here we go again another table build
:D Yeah Craig...the best toys you can have are the ones you get someone else to pay for! I love those corners you bend. I am flirting with buying a electric log splitter and fabbing up a hand brake out of it. Can't wait to see your table....keep us posted....Jeff
    near Chicago
Were those corners done with the tiggerator or the miggerator? I gots to get me a bender and a roller.
motox
    Delaware
finished coffee table corners
IMG_1598 corners 4-3.jpg (95.22 KiB) Viewed 2919 times
IMG_1596 corner 4.jpg (112.43 KiB) Viewed 2919 times
IMG_1605 coffee corners finished.jpg (108.23 KiB) Viewed 2919 times
IMG_1603 corners 4-2.jpg (117.92 KiB) Viewed 2919 times
motox
    Delaware
table frame blackened and urethane coated.
wood top finished and at Delaware house
waiting for frame to be assembled.
IMG_1627 table 2-2.jpg (117.4 KiB) Viewed 2895 times
IMG_1626 table 2-3.jpg (117.88 KiB) Viewed 2895 times
IMG_1623 table 2-1.jpg (107.13 KiB) Viewed 2895 times
taz
    Mon May 26, 2014 12:43 pm
    Athens - Greece
Nice.
I may steal your designs for some balcony furniture.
motox
    Delaware
taz
you are more than welcome to it
I'm sure you will improve it.
motox
    Delaware
taz
your fume extractor, how close to the weld
can you put it with it messing with the argon?
taz
    Athens - Greece
I have not tried it when tig welding. Only when stick welding so far. It works surprisingly well, I place the nozzle 15-20cm away from the weld and it sucks all the fumes from stick welding.
I have a Speedglas 9100FX Adflo which is my favorite welding hood which I use when Tig welding.
However the fumes when tig welding carbon steel are nothing to worry about especially if you are not welding full time.
I will try it though and let you know.
motox
    Delaware
taz
here is a photo of the first table finish
and heading to new home.
IMG_1526 1st table finished.jpg (153.16 KiB) Viewed 2353 times
taz
    Athens - Greece
Looks great. What type of wood do you use?
motox
    Delaware
taz
the wood is Meranti
decking.
taz
    Athens - Greece
Thanks. I am thinking about using bangkirai for the fence of my new house which seems belongs to the same genus.
It will look something like this with slightly bigger gaps.
ImageUntitled by Taz00, on Flickr
motox
    Delaware
taz
i love to see it
i do exteriors for a living
so this interests me.
taz
    Athens - Greece
Great then you are the man to ask.
I am torn between metal and wood.
I prefer the way wood looks but I am afraid it will require more maintenance.
I feel more comfortable working with metal but the square tubing I am looking at (100x20mm ~ 4"x5/8") comes only up to 1.5mm thickness. Usually tubing this thin after 10-20 years starts rusting.
I have a colleague that says wood like teak (too expensive) and bangkirai are maintenance free. Do you have any info on them?
If I decide on metal I want to paint it using one of those "wood effect" paints. I do not know if the final result is decent so will try some to see how it will look.
motox
    Delaware
taz
most of my work is with PVC (azek) trim.
most of the time the general contractor has his
house crew install the decks. Meranti is the
wood of choice but i have seen them use
bangkirai although it is not very common here.
i do know a bit about it though is very durable and can handle
weather well.
it does not like to be painted as it sucks the paint
into the grain which can cause checks and cracks.
I'm sure it would be wonderful material for a fence.
you will need very very sharp tools when you cut
or drill it as its very dense. nice grain and appearance.
hopes this sheds some light on the project.
here is a sample of our work
IMG_1440 duddy posts.jpg (110.87 KiB) Viewed 2329 times
taz
    Athens - Greece
Thanks for the info.
Great work. PVC is rarely used in houses here. If someone were to build something like what is in your pic it would be out of marble with a price to match of course.
motox
    Delaware
taz
keep me up to date on your projects!
motox
    Delaware
coffee table and sofia table
finished and in service in
Delaware house.
Craig
IMG_1658 coffee del.jpg (113.13 KiB) Viewed 2515 times
IMG_1663 tall table del.jpg (121.38 KiB) Viewed 2515 times
IMG_1659 coffee del best .jpg (126.33 KiB) Viewed 2515 times
I like!
Sort of "Industrial meets Shaker".
Are those casters hard on the floor finish? They look to be ABS plastic, which can pick up and hold grit.
delraydella
    Mon Apr 25, 2011 7:35 pm
    Detroit, MI
Very Nice!
motox
    Delaware
steve
we are just starting to furnish, paint, decorate this
house and there will be area rugs where tables will wind up.
thanks for noticing though ill keep that in mind for future
projects.
what materials would be an option?
Craig, area rugs are the best fix, obviously, but wheels made of HDPE (the same as plastic cutting boards) are less prone to capturing grit (like sand). I suspect there are even better choices available, but I've not worked in plastics since about 1990.
If nothing else, HDPE is usually white or light-colored, and hides the dirt tracks/scratches that show on your present casters.
A search for casters filtered with "food grade" may yield interesting results.
