Dragster Guy
    Wed Jun 11, 2014 7:19 am
    Pasadena MD
Well Im just starting my new business Performance Metal Works and this is what i have been up to so far.Building Headers :D
Pasadena MD
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
Headers are on my "list" of things in want to build someday. Explain to us how you built them, what material, did you purge then inside etc . Great job!
Dragster Guy
    Pasadena MD
Superiorwelding Thanks for the compliment. When building headers it is important to try to make all the tubes the same length. I start with the front port and figure out where it needs to run as not to interfere with anything also looking at where the other tubes need to run. it takes a lot of trial and error.I will only tack the joints on the tubes till i am satisfied with the header. i do not weld to the flange till last that way you can weld the tubes easier.I do not purge the tube to weld it. every thing is tig welded. I buy a random bend kit an the proper flange set from Schoenfeld and just start cutting and fitting. This set took me 40 hours to build. Hope this helps.thanks Dragsterguy
Pasadena MD
Wes917
    Fri Oct 25, 2013 11:45 pm
Nice work, to save some time I would recommend these. They are on my list. I used trimmed down pool noodles to mock up a set for a bike one to save some time but if I was going to be doing a lot of sets I would be snapping these up.
http://icengineworks.com/
http://m.summitracing.com/search/brand/ ... ts=display
RichardH
    Sun Jan 12, 2014 10:45 pm
    Chandler, Arizona, USA
These guys sell parts, but also offer fabrication services. Their approach to fitting up with PVC and then building a support frame seems pretty clever. Interesting DIY videos:
http://www.stainlessheaders.com/headerfabrication
I too think this would be a cool project to tackle - lots of craftsmanship. My kids are eager for me to use their cars for the project. ;-)
Edit: That modular kit from IC looks pretty neat!
Cheers,
Dragster Guy
    Pasadena MD
Thanks guys I really like to do these builds its always a challenge.
Pasadena MD
newschoppafowah
    Wed Feb 19, 2014 11:54 pm
Interesting stuff.Good to see a header build around here.
Good luck with your new business! :D
Sent from an earthen ditch outside Needles, CA using an awful lot of low voltage single strand wire.
It's a matter of flour and water and then there's the seasonings, which is a matter of salt and so forth and then you h-we interrupt this for the announc
Dragster Guy
    Pasadena MD
Thanks its been kind of slow. I have 2 enclosed trailers to repair in the next few weeks i will post some pics.
Pasadena MD
Dragster Guy
    Pasadena MD
A little Rad repair. Had a crack in the tank at this mount.
Pasadena MD
