MFleet
    Sat Dec 10, 2016 5:26 am
    Houston, Tx.
Hope everyone is doing well! I'm not familiar with mounting these and I'm looking for ideas. The outer measurements on the bed c-channel is 38" and outer measurements on the rectangular tube frame is 42" for 2003 Ram 2500.
Screenshot from 2026-07-12 13-23-26.png (1.21 MiB) Viewed 7714 times
Miller 350P w/Python
Hypertherm Powermax65
Lots of simple options. Stock beds often use a long bolt through bed to a captured nut inside the frame or beyond the frame. Long U-bolts are reliable too.
You’re not providing a lot of information or decent photos to provide any better ideas.
MFleet
    Houston, Tx.
cj737 wrote: ↑Thu Jul 16, 2026 10:00 pm Lots of simple options. Stock beds often use a long bolt through bed to a captured nut inside the frame or beyond the frame. Long U-bolts are reliable too.
Sure thing, cj. Adding some pictures of the frame. Are the pictures of the bed sufficient?
I'm thinking that the shock tower will have the tallest gross interference. That leads me to a thought of removing most of the rear C channel on the bed. The ultimate goal is to have a mobile deck at roughly elbow height. It is not expected to carry more than a 2000 pound load, but sometimes at a high center of gravity. The gooseneck bracket is not useful for towing anymore, but it could be chopped up and re-purposed as a bed support.
Screenshot from 2026-07-26 13-35-00.png (873.87 KiB) Viewed 7012 times
Screenshot from 2026-07-26 13-37-04.png (1.85 MiB) Viewed 7012 times
Screenshot from 2026-07-26 13-38-08.png (720.27 KiB) Viewed 7012 times
Screenshot from 2026-07-26 13-38-52.png (1.7 MiB) Viewed 7012 times
Screenshot from 2026-07-26 13-36-22.png (657.56 KiB) Viewed 7012 times
Notch the bed channels and weld on tabs that extend down the chassis. Drill holes in the tabs and thru the chassis and run grade 10 bolts thru, securing the bed to the chassis. Easy to remove, no altering of the chassis.
