I am in the process of welding up a weathervane with 16oz copper sheet with de-oxidized copper rod with my syncrowave 250 and wondered if anyone has any experience in doing this...settings,electrode etc?
Start out around 30 amps. Use a foot control or thumb wheel. You might need to bump the max up 5 amps at a time or so to find a good puddle point. Depending on overall mass copper can pull heat away pretty fast , so it may take more than you think. But after it gets hot it may take much less. That’s where the rheostat comes in.
The numbers on that chart look a little more like what I was doing. My amps were pretty high because I couldn't even get a puddle started at low current.Poland308 wrote:From Harris
https://www.harrisproductsgroup.com/~/m ... meters.pdf
I have 20 oz copper because I used it for flashing on my chimneys. I just played around with some of the pieces and had fairly decent luck with welding it but I did put a lot of heat in the part which anneals the material something terrible. If I had more time to play with it I would probably get some of that water putty stuff that you used to sink heat out of your part. There's got to be a better way than what I was doing. I used clean Romex as my filler rod. 14 gauge. Straight argon and DC at I want to say 100 to 150 amps but it's been a while so I don't remember.
