rahtreelimbs
- rahtreelimbs
Need more info. metal type - thickness . Stuff like that.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
rahtreelimbs
- rahtreelimbs
Any gap in the joint?
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
rahtreelimbs
- rahtreelimbs
rahtreelimbs wrote:Metal 1/4" carbon steel. Welding a butt joint one on top of another!
Some yes .....some no.
Sarge
- Sarge
I am guessing that you really mean "vertical" welding? What type of welding are you doing? Mig? Tig? Stick? Would love to help with more info...
Be Innovative.
Goal is perfection, but excellence is Acceptable.
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
Powermig 255C
Powermig 350MP x2
175 squarewave
Weld-pac 100
Hypertherm 600
Hypertherm 1250
Steve from Ohio
- Steve from Ohio
Go to the top of this page and click on the logo "WeldingTipsandTricks.com" and it will take you to the main menu.
Then check out the Mig welding tips and tricks. Jody has all kinds of videos that will show you how to weld vertical and horizontal or any way you want!
They are excellent videos and Jody does a great job of making his points about welding without a lot of BS. HE just does it and shows you how.
I think you're talking about overhead horizontal welding is that correct? If so the trick is to turn the heat down a little and slow down. You want the puddle to freeze almost immediately after moving forward but not so quickly as to cause a cold weld. It's one of the toughest welds to do and takes practice so don't get discouraged if it's causing you problems, they cause everyone problems.
