Hey guys, curious if anyone knows if you can run an xtreme 12vs off of an cst 280? Cst 280 is basically an inverter stick welder with a very plain jane tig function. I'm just curious because the cst is way more portable than an xmt is. Xmt does have a function for cc/cv and a vs option, but im guessing the cst is just basically a cc machine and the amps would have to be controlled from it instead of the feeder. I get the basic principle but don't know a lot about the circuitry
Thanks, Jake
What wire are you planning to run, on what material?Jake Matthew wrote:Hey guys, curious if anyone knows if you can run an xtreme 12vs off of an cst 280? Cst 280 is basically an inverter stick welder with a very plain jane tig function. I'm just curious because the cst is way more portable than an xmt is. Xmt does have a function for cc/cv and a vs option, but im guessing the cst is just basically a cc machine and the amps would have to be controlled from it instead of the feeder. I get the basic principle but don't know a lot about the circuitry
Thanks, Jake
Self shielded flux core runs great on your cst 280.
Mig and duelshield not very good.
Jake Matthew
- Jake Matthew
Most likely just be mild steel, .035-.045 wire. I was just considering the cst 280 as a power source because it's easily portable. What makes it different from running on that as opposed to an xmt with a vs option?
