I have a Lincoln 135 mig and the only training I have ever had was the two hour crash course that was complimentary with the purchase. I'm not the best, but can get good penetration and usually a cosmtically consistent bead. I am working on a tube frame rockcrawler and most of the material is 2" od .12 wall round tube. I know it is not recommended to weld upside down, but it's not like I can just flip the vehicle over to complete the welds underneath. Any tricks to keep the little molten balls of metal from building up, falling on me forcing me do a silly dance whle mutteing profanities?
Thanks,
David
scragglepoo
- scragglepoo
FLApipedisciple
- FLApipedisciple
Dittobrian wrote:Use the same setting as flat, keep a very short stick out. I personally try to keep my angle straight in, no push or pull.
If you follow the old timers advice do the cursive e a circular motion will allow you to follow or leed the puddle in any direction with out worrying about the end fill creater at the end of the run tie and draw back on it circular motion for mig works great if you can turn the nozzle end peice to the left 30deg or right 25deg for lefties
