Greetings from South Africa
I recently acquired a mig welder with separate wire feeder on auction.
It didn't come with the inter connect cable so I opened it up to see if I can figure out the wiring needed for the cable. It has a 7pin on the machine and 6 on the wire feeder.
The thing that confuses me is that on the wire feeder there a knob for voltage and a knob for current adjustment, but nothing for wire feed speed. On the power source there is 3 knobs, crater fill voltage, crater fill time, inductance.
It looks like a original label from the factory but judging form the fact that its a chinese machine its possible its labeled wrong.
I had a look on the net and its seems that there are other wire feeders with the same labels.
This picture shows a feeder on the net with the same labels.
I am used to mig machines having a voltage knob or sometimes incorrectly labeled as "current" knob and then a wire feed speed knob.
I haven't connected or powered up the welder yet, will have to test the pins first to figure out the pinout. So I am not able just to play with the knobs and see what happens.
Is it possible that the current knob is actually the wire feed speed, since wire feed sort of determines the welding current?
Thanks
