Moved over the the caster install for our racks. Let me know what you think.
Hmmmmm wish the pic was clearer....
So the more noticeable brown staining is from too much air entering the weld zone/ie, too much stick out, is this what you are saying?Otto Nobedder wrote: Note the color difference, there's a li'l bit of air mixing on the verticals.
Yes. Note the shine on the horizontals, versus the grey color on the verticals. This is pretty common. On a horizontal weld, it's easy to keep the gun in tight and close to square to the work, and still see the puddle clearly. On the vertical, you're usually looking down from the top, and on a vertical "down", the puddle (and smoke) is between your eyes and the arc. This leads people to pull the gun back a bit to see better, on top of the natural tendency to drag the gun more than needed. Vertical down works well with 10-20* of drag angle, but the more angle you use, the less stick-out it will tolerate due to the nature of the gas flow plus the convection (updraft from the heat) to draw air into the cover gas. This mixing also increases the "smoke-stains" around the weld.Follow da blue light wrote:So the more noticeable brown staining is from too much air entering the weld zone/ie, too much stick out, is this what you are saying?Otto Nobedder wrote: Note the color difference, there's a li'l bit of air mixing on the verticals.
