- Wood Welder
Lately, I have been getting occasional flashbulb-like flashes during welding on carbon steel and stainless. One particular project had some internal rust on mild steel tubing. I recently switched to an auto-darkening helmet but it wasn't doing this at first. My straight argon cylinder is below 500psi while this is happening and the cylinder has been stationary (not agitated). The flashes last a micro second and are not horribly bothersome. What gives?
Lincoln 100 amp transformer MIG w/flux core wire
HF TIG w/no pedal for steel & stainless, Stick w/3/32 6011,7018
Formerly: Victor O/A and Lincoln 225 AC buzz box
Looking to upgrade
Bikes-XR250, CRF230
Looking to upgrade
Bikes-XR250, CRF230
Turn the delay up ,so sensors don't react so fast.
fiddle with the sensitivity to get balanced for welding amps/material one is working with.
ESAB 613XL
I tend to run my shading #'s darker than a fixed shaded helmet lens. helmets/users one size does not fit all
Just another stubborn midwest opinion.
ESAB 613XL
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
- Wood Welder
The original CR2032 lithium batteries read 3.04 volts.
I increased the delay and I'll work with the sensitivity. If that doesn't fix it, then I'll put in the new Lithiums which read 3.32v.
Thanks
I also need some sort of black cloth to shield the stray light coming into the back of the helmet since I usually weld outside in the shade. Maybe not the best situation for the shielding gas.
Thanks
Looking to upgrade
Bikes-XR250, CRF230
Looking to upgrade
Bikes-XR250, CRF230
dave powelson
- dave powelson
ditto sensitivity and delay adjustments
It's easy to intermittently block the sensors, especially with low buck helmets
that have only 2.
that have only 2.
I also need some sort of black cloth to shield the stray light coming into the back of the helmet since I usually weld outside in the shade. Maybe not the best situation for the shielding gas.[/quote]
card board and tape for weld, wind breaker
Damp shop rag/towel over top of helmet,blocks stray light and helps cool (my hot head
Everlast 250EX
weldit321@gmail.com
- weldit321@gmail.com
If you are willing to try another welding helmet, I would recommend the Miller digital series. They have what they call X-Mode which is not light sensitive but rather senses electromagnetism (same 1/10000 of a second reaction time) and I use it all the time. Plus they are great helmets and are reasonable for the quality. And as with light sensors the sensitivity is adjustable so someone next to you welding will not trigger your shade to go dark.
I only really see the issue on flux welder's helmets but dirty lens covers will prevent the sensors from behaving correctly too.
-Sandow
-Sandow
-Charles Dickens
-Charles Dickens
- Wood Welder
Increasing the delay time solved the problem.
The same old batteries work fine, too.
Many thanks!
Many thanks!
Looking to upgrade
Bikes-XR250, CRF230
Looking to upgrade
Bikes-XR250, CRF230
