Filled a couple holes in a backbone and ground them down smooth. The sharp point on the tungsten dulls fairly quickly. Now I want to fill the small creases/ crevices in the weld. What's the best way? Same amperage or less?
I don't sharpen until the arc wanders at weld current. I don't have time or inclination to run to the grinder every time it's not perfect, and a blunt/crapped up tungsten will still weld fine if you're practiced in what to expect.
This is not a suggestion for a newbie, of course, as you want to take all variables out of the equation until you understand what's going on. However, time and practice will teach you how messed up your tungsten can be before you have to fix it.
Otto Nobedder wrote:I don't sharpen until the arc wanders at weld current. I don't have time or inclination to run to the grinder every time it's not perfect, and a blunt/crapped up tungsten will still weld fine if you're practiced in what to expect.
^ this. I'm glad somebody else will preach this as well. Run scratch start/lift arc and you learn to live with it. If it melts the metal, weld it. Except I like it fresh for a root pass. Helps to buy a few dozen too and sharpen em all and keep them with you.
Yep, I am in the club of don't go to the grinder until it pisses me off.
After you push the limits for a few times it becomes clear not only what you can get away with but also you learn where your personal limits are for quality and appearance. Just pick the places you try this based on how critical the job really is. If appearance is important than don't cut corners. If someone's saftey down he road is involved don't cut corners. If it's a pipe with 20 PSI water giver hell and don't let it drip till after you leave!
DLewis0289 wrote:Yep, I am in the club of don't go to the grinder until it pisses me off.
I'm in agreement with this unless I'm doing sanitary or xray work. I think everyone should learn scratch start...
The good old days, Heli-arc (helium), scratch start, gas valve on the torch and transformer welder.
