So I'm going to take a test in a couple of days, tigging 1/8" thick mild steel, t joint, vertical. I have been using 3/32 tungsten and same size filler for 2F(horizontal tee), @ 93A, DCEN, with foot pedal. I have been walking the cup with 2F position tee joint. My questions are:
Should I use different amp setting, different size filler rod, or different size tungsten when tigging a tee in 3F position? Also should I freehand in this position, or try walking the cup? (I have walked the cup before in this position, but it has been about a year since then, and I can't remember much about the required technique anymore).
I will be able to practice for a cumulative 8 hours before taking the test, starting tomorrow evening.
Thanks for your input.
How have you been doing with your practicing until now? What problems are you experiencing? All your welding parameters seem to be ok. I would run just a little more on the amps, but it sounds good. As for freehand or walking the cup, that is up to you and what you feel comfortable with.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
kermdawg
- kermdawg
What Jpence said. All depends what your comfortable with. I only walk the cup when I weld pipe, and even then I freehand the cover pass. Everything else I freehand, but thats just the way I was taught.
