Thanks,
Joe
That was my first thought also but after the weld has been started there shouldn't be any difference in the ground between the pieces. I'm more inclined to think that the tungsten grind is the problem. The tungsten shoud be ground to look similar to a freshly sharpened pencil. Make sure you use a dedicated grinding wheel that has never been used for anything else and never dressed with a wheel dresser.tigmaster wrote:sounds like you might have a bad ground....
http://www.arc-zone.com has them. Be prepared for a little sticker shock.Joe wrote:Steve,
Can you tell me where to buy Sylvania tungstens? I have some tungstens from Diamond Ground that should be good and seem to work well. I was able to buy those after someone posted a seller on ebay. A couple of welding supply places on the internet couldn't tell me what brand I would get if I ordered from them ??? which didn't make much sense when I keep reading in books that the quality of the tungstens is really important.
Joe
