Guys, I have a wear point on a piece of equipment that is dealing with some impact and is deforming the 1018 steel a bit. I was curious if any of you have a recommendation of a filler metal I could use to run a tig bead around the contact area to reduce the peening/deforming.
I can't really use standard stick hard facing rod as the area is pretty small with critical dimensions around it.
Would a 80 series rod help?
- Braehill
csolo,
Kennemetal makes a rod called Stellite ( not sure of spelling) that can be Tig welded or O/A overlayed. It's Cobalt based, but nickel based rod will work also, they make those too but I can't recall the name, Doro-something.
dirtmidget33
- dirtmidget33
Brehill Is Deloro the name you are thinking about. found this link might help you choose a rod type
http://www.stellite.com/ProductsService ... fault.aspx
I never used any of these rods, found link was just reading, I was curious about hardfacing with TIG after reading your question.
May sound cheap but I have tigged on my stick hardweld rods just fine. Just knock off the flux with a hammer and a quick buff on the wire wheel. Even looks purdy. Try a bit on some scrap if you have some. It is a surface bond.
I have a ton of stick rod left over from doing my bucket repairs way back lol. 7018, 11018, 6011, LoCroMo and others.
They're junk for stick welding now with out treatment so I use them when tigging something I should be sticking (but I won't because I hate the fizzle and clean up now and it's just about as fast).
Same thing, knock off the majority of the flux with a hammer but now I don't even buff it. The remaining bit of flux on the rod just cools on the surface and flakes off like fish scales off the ripples leaving spatter free tig weld.
- Braehill
I've also Tig welded more than once with a stick electrode with the flux removed, and even stuck a few 7018's in the collet to weld something I couldn't reach with the Tig. I even fixed a striker plate in a door of an old van once with a Bronze brazing rod made for O/A (flux on) using the Tig torch because I was out of Oxygen, lasted longer than the engine in the van. Any port in a storm.
