I have a weld test tomorrow 4 inch pipe 6g. I'm not sure what thickness but it has to be 100% X-ray tig all the way out can you give me some parameters to go off of I am up at school practicing and I really need to get this job. Thank you
-Stephen
For 4" sched 40, my preferred method:
30 degree bevel, no land, 3/32" gap, 3/32", er70 wire, 3/32" electrode.
Root pass: 105amps laywire
Second pass: 110amps (fill the joint)
Cap pass: 125amps (no stringers, single weave cap)
Good luck!
Good luck!
StephenPerkins
- StephenPerkins
WOW!
An x-ray test on pipe, and you've never hand-beveled before?
And you don't know any of the parameters of the test?
I appreciate the chutzpah it takes to do this.
Please let us know how it goes!
StephenPerkins
- StephenPerkins
Well I know the parameters I've just never welded 4" pipe before thought maybe it was different than 6"
You specifically asked, "Can you give me some parameters to go off of?"
That suggests you don't know the weld parameters.
If you have a WPS, post it up, so we have the same working range you're asking about.
