I am pretty confident with TIG'ing aluminum and mild steel. But I just tried stainless and I was not liking the results. I am not really well setup for stainless yet I don't feel; I don't have a setup for back-gassing the weld with argon, I think was my main problem. I also don't have any of the super side gas coverage cups. (I do have a #8 gas lens I think is about my best at the moment. I think the #8 gas lens works better than a #10 standard collet body cup I've also got.) I was welding some automotive exhaust tubing, which was mild steel I think, perhaps a mixture of some stainless components I wad welding on. Some pieces were "new", some were old (prepped the fornt side, dirty/carboned back side though.) I tried the 309L filler rod and found it was oxidizing on the back side where the argon couldn't reach, it was particularly horrible for filling wide gaps. There were occasions (filling a wide gap, or hole) where I could see the stainless oxides "swell up" (like a porous bubble inflating inside the material.) Ick. The oxides I feel were really messing up the "fluidity" of the puddle and I knew I wasn't getting good penetration with it like that either. E70S6 Mild steel rod was so much more fluid and easily workable on the same materials, in comparison. So I'm pretty sure to tackle more stainless projects successfully, I need to do something to better shield the back side of the stainless weld. (And perhaps even better shield the front side.)
I was just wondering if rather than messing around with back-gassing with argon (second flow meter, hose setup plugging apparatus, etc) if anyone is having success using "Solar Flux B" with TIG on stainless. I have used this when oxy-acetylene welding stainless, and it worked really well. Dare I say, with the solar flux, oxy acetylene welding stainless was more fluid, and went even more nicely than oxy acetylene welding mild steel without any flux! I still have some of the flux, and remember dissolving some in alcohol, and painting it on the weld joint (back, front, and in between.) The flux itself also seemed to stay quite inert after welding, so I didn't even need to hassle with removing it from the inside of the pipes (automotive exhaust, not "food grade" projects were talking about here.) Oxy welding stainless with flux did make quite the mess on the front side of the stainless weld however, and considerable mechanical effort was required to remove it and get a presentable looking result.
I was just wondering how well the Solar Flux works with the TIG process, since I haven't tried it yet, I know the flux manufacturer says it works. But I'm wondering if it makes a big mess of the appearance of the TIG beads? Is is possible to solar flux the back side of the weld and TIG it, and having it turn out nice looking without having to take a power stainless cup brush to remove the flux afterwards? Is anyone using it, or tried Solar Flux with TIG and have any comments? Should I just skip it and invest in the setup necessary to back gas welds with argon? I want to weld automotive exhaust, maybe some art work, who knows, probably not any food pipes though.
