The manual clearly defines how and why to use this adjustment. I just want to know (in the real world) how you guys are using this feature. It says to start with 7 (the selection is from 1 to 10) and tune it from there. It has something to do with adjusting the AC squarewave. It says, "Set at a higher value to decrease the arc cleaning (or etching) zone and increase penetration, or set at a lower value to increase arc cleaning action of the workpiece."
So am I fair to assume that with thicker metal I can turn this up and get better penetration, but will see less etching? On thinner metal turn it down and see more etching and get less penetration (and less burn through opportunities)? Is there anything more to this than that?
I won't even ask about pulse setting and whether or not that is a valuable option this welder is equipped with. Reading through the archives I can see that pulse receives a mixed review.
TIA for your points of view. Now back to practicing my left handed welding technique.
