Just got the new everlast 210 ext 2015 model. Having troubles trying to figure out a aluminin setup with the new panel. 1/4 inch aluminum plate. 17 ck torch with number 9 cup and gas lens. Any suggestions would help. Thanks u
The rule of 33 is for pulse settings, however alum is a little different. With the alum I'd do 180amps, 75% peak, 25% background an 1-2pps, dab at the pulse, 3/32" tung, 3/32" fillerRaffus wrote:Just got the new everlast 210 ext 2015 model. Having troubles trying to figure out a aluminin setup with the new panel. 1/4 inch aluminum plate. 17 ck torch with number 9 cup and gas lens. Any suggestions would help. Thanks u
Pulse will limit the heat you put into the part.
Put it in straight up AC, full pedal, and let it eat.
- J & J Speed Shop
You sound like a drag racer???AKweldshop wrote:.............
Check the " mug shot " topic - not sure he's old enough to drive !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
( sorry AK - could'nt resist )
- TRACKRANGER
Noddy c'mon now, unkind. Never mind about any car, that guy sure can weld, he's keen as, and helps others out heaps. And that's the main reason why he's here, (and the one that matters most).noddybrian wrote:Check the " mug shot " topic - not sure he's old enough to drive !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
angus
- angus
if you are going to be welding 1/4 plate regularly, you might consider a torch that can handle more amperage. also, nixRaffus wrote:Just got the new everlast 210 ext 2015 model. Having troubles trying to figure out a aluminin setup with the new panel. 1/4 inch aluminum plate. 17 ck torch with number 9 cup and gas lens. Any suggestions would help. Thanks u
the pulse.
OK - I meant no offense by it - I expect AK will take it as a joke - sometimes stuff does'nt come across in text the same as you meant it in your mind ( plus UK sense of humor difference ) - I always respected him & his work ( well except the 6013 hate thing ! ) I like his video's too - just never thought he was that young - I grew up on a farm & welded from an early age so can relate with him - just I'm turned 50 now & feel it some days! Funny thing is you get a mental image of how you expect someone to look based on how they write & most of the pictures look nothing like I thought - anyway sorry AK if comment was out of order.
- TRACKRANGER
Noddy B
All Good
I'm sure AK will take it on the chin without any issues. I somehow suspect there's a bigger future in store for Mr AK
All Good
Noddy, you should know by now that it takes a lot to offend me....noddybrian wrote:OK - I meant no offense by it - I expect AK will take it as a joke - sometimes stuff does'nt come across in text the same as you meant it in your mind ( plus UK sense of humor difference ) - I always respected him & his work ( well except the 6013 hate thing ! ) I like his video's too - just never thought he was that young - I grew up on a farm & welded from an early age so can relate with him - just I'm turned 50 now & feel it some days! Funny thing is you get a mental image of how you expect someone to look based on how they write & most of the pictures look nothing like I thought - anyway sorry AK if comment was out of order.
Carry on.....
Noddy??noddybrian wrote:Check the " mug shot " topic - not sure he's old enough to drive !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Who said I wasn't old enough to drive?
You calling me a helpless runny nosed kid?
Thanks bro.TRACKRANGER wrote:Noddy B
All Good
Don't worry Trevor, me and noddy go back a little ways.
We're cool
what about using pulse on really thin stuff 032 040 aluminum?
my syncrowave 250 does not have that feature but i
just got a htp 221 and it does have pulse.
- GreinTime
Experiment yourself moto and see what works. If you use a slow pulse, I. E. One pps or slower it can help with your cadence and you can eliminate it once you get the rhythm down. The background current settings have more to do with puddle cooling when using a slow pulse.
grein
i don't have problem with my 250 going any alum
just curious about features on inverter
thanks for your info
- GreinTime
I figured you didn't have any issues welding aluminum with the Syncrowave, I was just commenting on some things you can use the pulse for, even though that is not the intended use.
I like to play around with pulse just to see what it does to the puddle and the bead profile. I have never found a situation where I was welding anything that I absolutely needed pulse for, but it helped get back into the rhythm after not welding for a few months.
sam
ill mess around with the pulse soon.
i just got the inverter up and running so
the features are all new to me.
If you play with low pps you might want to increase the delay time on your helmet. Can be disturbing if the lens switches with the pulses.
- admin
- Site Admin
hey bud,Raffus wrote:Just got the new everlast 210 ext 2015 model. Having troubles trying to figure out a aluminin setup with the new panel. 1/4 inch aluminum plate. 17 ck torch with number 9 cup and gas lens. Any suggestions would help. Thanks u
I just used one of those new model 210ext tigs and here are the settings I used for an aluminum repair and they worked out pretty well on a 1/2" thick piece for a buildup repair:
AC balance 40
AC freq 77
I used a #8 gas lens (only because I was using it on steels) with argon set to around 20cfh ( probly could have got by with 15 cfh but wanted to extend the electrode for filming.
I set the start amps to around 25 so I would get a crisp start. but if you were welding aluminum sheet metal, probly a lower start amperage would be safer.
hope it helps,
jody
4EjRYhJgpiw
jody
just watched the video on line, great arc shots
and a bunch of useful info.
thank you for taking time to make these videos
they are a great help.
ps love the big TIG finger!
Motox,
I'll second everything you said! I love the detail Jody puts in his "no PhD" information.
I'm certain I've sold a TigFinger XL... A friend at work has the TigFinger, but borrowed my XL for a heavy-section job. He's hooked.
Good stuff, here, all around.
