- Braehill
That's an Inconel 82 rod if I remember correctly, and starting to get quite expensive, so I wouldn't waste it welding up lawnmower decks and the like.
jwright650
- jwright650
Judging by the "ni" and "cr"...I would venture a guess that it has higher percentage of nickel and chromium in it...
well just from a google search I found this:
Braehill was right, it's Inconel 82, an AWS A5.14 material
http://www.specialmetalswelding.com/pro ... h/fm82.pdf
John Wright
- Braehill
Motox,
No it's not made to weld dissimilar metals. That's not to say you can't weld a non- critical part together with it, but why would you waste expensive wire on them.
len
i get it.. after reading jwrights post and reading about, it using it
to do simple welds is like using lobster meat to catch eels
