root pass balling up
Posted: Tue Mar 11, 2014 10:00 pm
by waylinbrandon1
Hey , I'm doing my tig root pass with 1/8 filler metal and a 5/32 gap .Im feedeing the rod through top of pipe . Im running 80-85 amps and from 6-8 o clock the metal starts balling up . So I went side to side while feeding the rod and the metal balled up and dropped below radius of root pass .What should I do different?
Need Help
Waylin
Re: root pass balling up
Posted: Tue Mar 11, 2014 11:02 pm
by Superiorwelding
waylinbrandon1,
Here is a video that might help you out. Can you get some pictures up for us?
https://www.youtube.com/watch?v=UKaPIpxIneE
Posted: Wed Mar 12, 2014 9:51 pm
by waylinbrandon1
Thanks for the info on the video . I've watched for the hand positioning and torch angle to help me . I free hand instead of walking the cup . With a gap closer to 1/8 inch I do a lot better. Will try to change variables and send pic. tomorrow.
Waylin
Posted: Sat Mar 15, 2014 10:46 pm
by waylinbrandon1
[/img]
Posted: Sat Mar 15, 2014 10:56 pm
by waylinbrandon1
Hey , the root pass im referring to is the one in front .The one with excessive penetration was one of a earlier try. Any advice is needed and appreciated . I structural weld but don't see pipe welders too often because I'm at the shop most of the time . So any advice is good.
keep welding
Waylin
Posted: Mon Mar 17, 2014 8:31 pm
by Arizona SA200
I think its looking good but i must ask, why not walk the cup? It is good to learn both because some times you can't walk it.
Posted: Mon Mar 17, 2014 8:36 pm
by Arizona SA200
On the OP you were talking about filler balling up. It sounds to me like you are feeding in to the arc and not the puddle. Feed it back a little farther and see what happens.
Posted: Tue Mar 18, 2014 10:28 pm
by waylinbrandon1
I have tried walking the cup but not quite fast enough too walk the cup on root pass while feeding the filler metal but will practice more . Appreciate the feedback.
Keep Welding
Waylin
