Only necessary on metals like ss and ti, protects the back of the molten/hot pool from contamination . Same idea as the gas coming out of the torch.
I've done many a steel pipe/tube with a gas purge and a consumable insert.
Purging helps prevent any chance of contamination or defects from the back side of the
root pass. In many high pressure situations a small crack or porosity can lead to a catastrophic
failure. No matter what the base material is, if it's critical, it's usually purged.
