That'd be a "no".
They make transition pieces, one side stainless, one side aluminum, so you CAN join the two metals. I've used them joining 304 with 6061-T6 (this was for pipe... don't know about structural sections). There is a temperature limit, and the piece comes with an attached non-resetting thermometer strip to tell you the ultimate temp you've reached at the critical part of the joint.
I suspect it's a high-precision interference fit, with the aluminum sleeved inside the stainless, with the aluminum pre-shrunk in liquid nitrogen, and excess temps de-temper the aluminum and ruin the joint.
Yes, indeed.dewdrop9 wrote:Ok Steve so what if i wanted to weld stainless to steel would that work because you would use DC like you would use for both?
ER309 is specifically intended for welding carbon steel to stainless steel, and is done DCEN just like carbon steel.
And if you have it available, stainless MIG looks better (and welds hotter) with tri-mix than with 75/25.Fat Bob wrote:309/309L Stainless Steel MIG Welding Wire.
NYWELDERJim
- NYWELDERJim
Steve,
Can you elaboarte on tri-mix gases? If have heard several welders refer to them. What gases are blended together in what ratios for what materials? How much benefit does a tri-mix of gases provide? Thanks!
Jim
Jim
"Tri-mix" gas for stainless steel MIG usually refers to 90% helium, 7.5% argon, and 2.5% CO2.
"Tri-mix" can actually mean many things in the welding world, though.
Sad it's not standardazed...
NYWELDERJim
- NYWELDERJim
Thanks Steve. I saw in someone's recent post a statement abut a tri-mix tungsten. As if this welding technology wasn't complicated enough!
