Can Mild steel or Stainless be used as a backing when building up Aluminium edges?
I have no copper to use and the thought of buying a large piece just for a quick project doesn't really interest me.
I have done it. It works ok. You have to use a thick piece of steel and they will stick together a little bit where copper wouldn't do that but its not out of the question at all.
Be the monkey....
Stainless is the better choice, particularly in a marine application, as you're unlikely to contaminate a weld.
Brass works well, too.
ajlskater1
- ajlskater1
Becareful with brass it has since and out gasses, would not recommend it for backer over a gap. I have used it before and had that happen.
