New to tig, will be using a ck17 air cooled torch. I'm trying to understand collets, and could use an assist...
When do you use a split collet vs a wedge collet?
Does furick require a wedge collet?
Can a wedge collet entirely replace a split collet, or are both required (I'm not clear if a ceramic cup requires a split collet)?
I see the weldmonger FURICK #8 PRO COMBO KIT, SIZE 3/32, and it has both styles of collets, which confused me.
Thanks!
Ok, thanks. I wasn't clear on the interchangeability and certainly didn't know about the slight angle.
Split collets will distort with heavy amperage and heavy use. Wedge collets endure those conditions far better. I don’t use split collets any longer because as you use shorter tungstens and smaller back caps to get into tight spaces, it has been my experience that split collets will lose their grasp on the tungsten and the tungsten will slide out at the most inopportune time.
Thanks Jack and cj, that's helpful. I'm still scratching my head a little as to why weldmonger includes both styles of collets in some of their kits, but I won't worry too much on that.cj737 wrote: ↑Sun Dec 15, 2024 7:48 am Split collets will distort with heavy amperage and heavy use. Wedge collets endure those conditions far better. I don’t use split collets any longer because as you use shorter tungstens and smaller back caps to get into tight spaces, it has been my experience that split collets will lose their grasp on the tungsten and the tungsten will slide out at the most inopportune time.
Jack Ryan
- Jack Ryan
Probably because there will be someone who can't weld without a split collet - or vice versa.
Or perhaps it was determined by stock availability.
But you are right not to worry about it.
Jack
