Wildwelder96
- Wildwelder96
I need to weld 16 gauge aluminum. I only have 3/32 tungsten and filler rod right now. I have a 200 amp inverter machine with pulse. Can I weld 16 gauge aluminum with 3/32 tungsten and rod?
The 3/32" Tungsten size would probably be my choice, so shouldn't be a problem. The 3/32" rod might be a bit too large. I would probably grab 1/16" rod myself, but I believe some welders like a larger rod for the added heat control it allows.
What alloy of aluminum are you welding? What alloy of rod?
Wildwelder96
- Wildwelder96
The only aspect of filler rod size is to control how much of it you introduce into the puddle. If you have thin filler and need to fill a large gap, simply stuff more filler in. The opposite is also true. Thin material, small weld, just introduce less filler.
