I'm trying to teach myself to TIG weld with less than spectacular results. I'm a fairly decent MIG welder (along with stick and Oxy-Acetylene from way back), but TIG is driving me crazy.
With MIG, heat requirements are pretty much a matter of looking up the proper settings for heat and wire speed, making slight adjustments to "dial it in"and adjusting travel speed as needed for the proper penetration and bead size. TIG welding, well lets just say its not as easy. Aside from the newbie problems of dipping the Tungsten into the puddle and hitting the Tungsten with the filler rod, I'm having a devil of a time trying to determine travel speed, and developing a proper "dabbing" technique when adding filler rod. I can do OK when laying down a bead without filler rod, and managed to do a decent lap joint or two when fusion welding, but add in the filer rod and it all seems to break down.
I seem to start out OK, but then things go downhill fast. I generally follow the rule of 1 AMP per .001" of thickness for steel, i.e. setting my welder for 125 AMPs for 1/8 material, then using the pedal to control the heat. No pulse, ramp up or down or any of the features that the machine is capable of (yet) just straight DC and .3 seconds pre flow and 5 seconds post flow for the gas (100% Argon). The problem is that when using filler rod, my beads are very inconsistent. Some area are obviously to cool and others to hot...not to mention having to stop so often to resharpen the tungsten.
Since I'm used to pulling a MIG bead, it was a little difficult learning to push the TIG bead. Also to me, it seemed much easier to "read" the bead when pulling a MIG bead vs pushing a TIG bead. Is there a rule of thumb that relates to what I'm seeing as far as puddle size vs travel speed? Also the majority of my puddle seems to be even with or slightly behind the Tungsten, but it I increase my torch angle, the arc wants to jump around. Does a "dirty" or dull Tungsten cause this? I have no problem seeing the puddle, but the end of the Tungsten gets lost in the arc glare making it difficult if not impossible to judge the distance. If I darken my helmet to where I can see the end of the Tungsten, then I can't see the puddle, so I try to find a happy medium.
Once in a while I can get a bead running for more than an inch or two, but then the fingers on my torch hand start getting uncomfortably hot. I'm thinking this may be from the material itself rather than my grip (like a pencil).
My attempt at TIG welding Aluminum
I'm hoping to take a TIG class at the local community college this summer if they offer any, but for now, I'm stumped. Oh yea, one other thing, I've watched almost all of Jody's video's and still can't quite get the hang of it. They've definitely helped a lot, but I think it's time for some personal instruction in a class.
In the meantime any hints will be greatly appreciated.
