I have been lurking for a while and after getting my first tig welder and thought I would join , wanted to thank Jody for all the videos and work he has done as they are all very helpful .
I have done Mig for around 5 years in pre fabrication of steel rebar reinforcements and I decided I wanted to learn TIG welding for hobby use and just to learn something new : ) .
I have projects that id like to do someday based around both mild steel and aluminium .
These are the first attempts i have done so far , about 4 rods worth of aluminium and a few of mild steel .
My welder is a oxford 220A AC/DC , Torch - WP20 with standard gas lens and number 8 Cup , 8L/min of argon .
Settings used are 115A with peddle , 3.2mm blue tungsten , 2.4mm AL rod 4043A , 3mm AL plate 1050 grade , 70% penetration , 120Hz . So far i have dipped a few times and i seem to struggle with feeding the rod through my hand hence why the short beads and getting a smooth run
P1010717 by TwirlyWhirly555, on Flickr
P1010718 by TwirlyWhirly555, on FlickrThey do vary abit and are abit grainy due to me trying to get two hands and a foot to all coperate at the same time . I do have very long way to go with so much to pickup and lean but should be fun : )
