To spare everybody the most common info of threads like this one, I'm a new welder with a new Lincoln SW 200, w a new bottle of 100% argon.
What is pictured/utilized has been 0.9" 6061 Al plate, 2% lanth/blue 3/32" tungsten, and #7 and #8 gas lenses.
My first 2 runs EVER looked like this:
Chronologically, the bottom run was just using the torch only, no filler. Machine settings were 80A, 73% AC freq, no pulse, 120hz, 20cfh, ground clamp on table. The upper portion was me trying to start to add filler to the puddle with same machine settings.
The next day, I try to strike an arc with the same settings and get this (bottom corner area)
Trying to move the torch along results in this
The arc is simply out of control, jumping everywhere, despite having good torch angle and distance of tungsten to plate. Went through a whole stick of tungsten breaking off the blackened, dirty ends to fresh parts then ground to dull point with every attempt and subtle changes in machine setting. There is no change when I have the ground clamp on the Al plate vs on the work table. The heat of the arc even seems to jump 90 deg from the gas lens opening extending about 1-2 inches towards me and my hand regardless of torch angle (vertical, tipped away from me, tipped towards, used in either hand).
Initially I was working 4 ft from the front of the machine and wondered if the fan was causing drafts/turbulence. I move to be as far as the torch cable allows and get this:
Upper attempts at 100A caused the metal to melt VERY quickly without any appreciable puddle to form. Just crackled, dark stuff resulting.
Tried amps ranging all the way down to 60 and still got near burn-through of the plate except that it obviously took longer to happen. No usable puddle forming. Experimented with gas flow ranging from 8-30cfh, AC freq from 110-130hz, AC balance from 60% (minimum allowed on machine) to 80%. All with similar results.
I can hear gas flow out from the torch as I push the pedal. I haven’t put soap water on the connections to check for leaks...but have double checked all connections for firmness (all snug but not overtight/too loose).
I’ve heard of folks complain about “bad gas” w a tank not being properly labeled or inadequately purged before argon added. Do you think I’m getting results consistent with a gas issue?
I've watched various vids of instances where MIG gas was used but am not seeing the same dazzle of sparks...just armageddon happening beneath the torch
Appreciate any help. Thanks!
